on startup of axoloti (after trying the mentioned reset all) i get a different error now:
Axoloti version : 1.0.11-0-gc534986 build time : 28/08/2016 23:02:12 UTC
Link to firmware CRC 50A29AA2
Current user library does not match correct version master -> 1.0.11
Stash (stash) FAILED : community (1.0.11,anon)
org.eclipse.jgit.api.errors.NoHeadException: HEAD required to stash local changes
at org.eclipse.jgit.api.StashCreateCommand.getHead(StashCreateCommand.java:225)
at org.eclipse.jgit.api.StashCreateCommand.call(StashCreateCommand.java:242)
at axoloti.utils.AxoGitLibrary.createStash(AxoGitLibrary.java:247)
at axoloti.utils.AxoGitLibrary.upgrade(AxoGitLibrary.java:199)
Current factory library does not match correct version, upgrading master -> 1.0.11
Stash (stash) FAILED : factory (1.0.11,anon)
Sync (pull) FAILED : factory (1.0.11,anon)
org.eclipse.jgit.api.errors.TransportException: https://github.com/axoloti/axoloti-factory.git: cannot open git-upload-pack
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:134)
at org.eclipse.jgit.api.PullCommand.call(PullCommand.java:267)
at axoloti.utils.AxoGitLibrary.pull(AxoGitLibrary.java:331)
at axoloti.utils.AxoGitLibrary.sync(AxoGitLibrary.java:70)
Caused by: org.eclipse.jgit.errors.TransportException: https://github.com/axoloti/axoloti-factory.git: cannot open git-upload-pack
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:518)
at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:296)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1179)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:128)
... 18 more
Caused by: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at sun.security.ssl.Alerts.getSSLException(Alerts.java:208)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1906)
at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1889)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1410)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1513)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1441)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:338)
at org.eclipse.jgit.transport.http.JDKHttpConnection.getResponseCode(JDKHttpConnection.java:98)
at org.eclipse.jgit.util.HttpSupport.response(HttpSupport.java:174)
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:469)
... 23 more
Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at sun.security.validator.PKIXValidator.(PKIXValidator.java:90)
at sun.security.validator.Validator.getInstance(Validator.java:179)
at sun.security.ssl.X509TrustManagerImpl.getValidator(X509TrustManagerImpl.java:312)
at sun.security.ssl.X509TrustManagerImpl.checkTrustedInit(X509TrustManagerImpl.java:171)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:184)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1491)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
... 33 more
Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at java.security.cert.PKIXParameters.setTrustAnchors(PKIXParameters.java:200)
at java.security.cert.PKIXParameters.(PKIXParameters.java:120)
at java.security.cert.PKIXBuilderParameters.(PKIXBuilderParameters.java:104)
at sun.security.validator.PKIXValidator.(PKIXValidator.java:88)
... 45 more
Sync (pull) FAILED : community (1.0.11,anon)
org.eclipse.jgit.api.errors.TransportException: https://github.com/axoloti/axoloti-contrib.git: cannot open git-upload-pack
Status: factory (1.0.11,anon) : OK ( master,clean )
Status : home : OK
Status: community (1.0.11,anon) : OK ( master,clean )
search path : /home/lokki/axoloti/axoloti-factory/objects
search path : /home/lokki/axoloti/objects
search path : /home/lokki/axoloti/axoloti-contrib/objects
finished loading objects
