HI Everyone,
In my Eurorack system, I use 3 8hp Axoloti modules that I've DIYed. My modules have 8 assignable pots, audio out, and audio in/CV with clipping protection so higher voltage Eurorack modules won't fry the Axo. I'm offering some of the spare PCB boards from my project for sale if people are interested. I teach beginning soldering workshops occasionally, and I think this would be a pretty easy DIY project even for total beginners. If there's interest, I'd consider doing a revision (or a second run with PCB/Panel kits maybe) and incorporating some other ideas.
Here's what the Axoloti modules look like in my own system. My system uses banana jacks, but it's Eurorack in every other way, and you can use whatever jacks you want. Please pardon the spaghetti.
Here's what the protection circuit does. Axo can be damaged by voltage exceeding 3.3v.
This is the back of the board -- the smoothing caps add a layer of defense against unwanted system noise, and help with analog to digital jitter a little bit. You could probably use larger caps and slew to your taste.
Here we are connected to the Axoloti:
Here's a vid of the pots talking to Axo. I can share the user device I made if you'd like.
$10. It can be yours! lolol. Comment here with questions or if you want one.
