Hello
Firstly: Should I expect to see the display dial integers moving independently when my pot is connected?
I turn the pot and it causes the patcher/display object to turn with some jittery after effect. Without turning the display object fluctuates independently after the decimal place.
I use the patch in the Getting Started Book (I am a newbie to this). All my pots are B10k Alpha pots.
Secondly: When connecting multiple pots to the board, do I connect to ground and VDDA for each pot (I have only used one pot)
I read that VDDA gives the best return for use with pots. Does it really matter if I use VDDC instead.
Thirdly: How do I connect multiple pots as there are only 2 VDDC and 2 VDDA?
Sorry that these are basic questions but....that is where I am at with this! I have looked through the boards here and the books and YouTube but cannot see the answer.
Many thanks!
