Hi there,
I tried several analogue inputs and all of them are very noisy. My config is just a simple pot (extreme pins go to VDD and ground, and central pin goes to analogue input).
The result is extremly noisy. Do I need to insert a caps in somewhere or else ?
on another hand is it possible to display the 12bit datas, the analogue object is blue and only permits display of 7 bit...
Thanks
