hi folks!! need urgent help!!!
i hope not to be OT in this category...anyway...
i updated my axo to the 11 version
in two different computers (Mac...yosemite and el capitan)...
after that i started to have problems with firmware and libraries..
in both cases
i search for the help of @thetechnobear and he solved gently a part of my problems...
but now my axo is blocked cause everytime that i try to open a patch the messages are:
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0x50A29AA2, entrypoint=0x20011000
Generate code complete
Start creating directory on sdcard : /anthem
creating dir: /anthem
Done creating directory
Changing working directory on sdcard : /anthem
file error: FRDISK_ERR, filename:"/anthem"_
Change working directory: /anthem
Start compiling patch
BDIR = /Users/Francesca/Documents/axoloti/build
FIRMWARE = .
RM
rm -f /Users/Francesca/Documents/axoloti/build/xpatch.o /Users/Francesca/Documents/axoloti/build/xpatch.elf /Users/Francesca/Documents/axoloti/build/xpatch.bin /Users/Francesca/Documents/axoloti/build/xpatch.d /Users/Francesca/Documents/axoloti/build/xpatch.map /Users/Francesca/Documents/axoloti/build/xpatch.lst
APP
arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -Wunused-parameter -DCORTEXUSE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -fno-math-errno -fno-threadsafe-statics -H -I/Applications/Axoloti.app/Contents/Java/CMSIS/Include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx/CMSIS/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/kernel/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/GPIOv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/I2Cv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/OTGv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/RTCv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/SPIv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/TIMv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/USARTv1 -I/Applications/Axoloti.app/Contents/Java/chibios/boards/ST_STM32F4_DISCOVERY -I/Applications/Axoloti.app/Contents/Java/chibios/ext/fatfs/src -I. -I/Applications/Axoloti.app/Contents/Java/chibios -Winvalid-pch -MD -MP --include /Users/Francesca/Documents/axoloti/build/xpatch.h -c /Users/Francesca/Documents/axoloti/build/xpatch.cpp -o /Users/Francesca/Documents/axoloti/build/xpatch.o _
! /Users/Francesca/Documents/axoloti/build/xpatch.h.gch
LINK
arm-none-eabi-gcc -nostartfiles -Tramlink.ld -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb -mno-thumb-interwork /Users/Francesca/Documents/axoloti/build/xpatch.o -Wl,-Map=/Users/Francesca/Documents/axoloti/build/xpatch.map,--cref,--just-symbols=./build/axoloti.elf -o /Users/Francesca/Documents/axoloti/build/xpatch.elf
BIN
arm-none-eabi-objcopy -O binary /Users/Francesca/Documents/axoloti/build/xpatch.elf /Users/Francesca/Documents/axoloti/build/xpatch.bin
Done compiling patch
Start uploading patch
bin path: /Users/Francesca/Documents/axoloti/build/xpatch.bin
block uploaded @ 0x20011000 length 21880
Disconnect request
Done uploading patch
(this is an example from the yosemite mac that it is not my mac)
sometime the patches work but a lot of time they don't work
i have set the starting patch and everytime i plug the axo usb this patch works
but if i open it as usual it does not work
please help me
every idea is welcome
