ps.: in my case sometimes the copy/paste works .....sometimes does not work!!!
What's happening?!?!
I tested synth/anthem on my Macbook(details in my "about me" section).
And it went live 10 out of 10 times.
hi jan and johannes
i also have these problems. on my machine tend to happen with larger (?) projects involving sd sample playback. i also use 10.9.5 and had axoloti version 1.0.9, then 1.10 then 1.11 installed. maybe should try to remove all past references.
also, when there's a big patch running on startup the axoloti may not enter card reader mode. in that case i first have to upload a tiny patch and then it can enter the card reader mode.
i've attached the patches which cause the issue for me. __pno.axp (40.9 KB)
they need some samples called pno1 through pno8 to run and the streamer.h and the play fn stereo done.axo. play fn stereo done.axo (2.7 KB)
bests,
const
hi!!! first of all thank for this patience...
a little update in delay...
i deleted my build directory....but nothing new
