you dont need to copy it... @johannes did a merge yesterday.
please can I strongly advise people NOT to start copying things from github into there local libraries.
this is not how the community library is intended to work, and can cause spurious errors, especially if objects are later updated..
if you want these objects you should wait until we merge them... if you want them quicker, then you should try to convince @SirSickSik to move to 1.0.11, as I have kindly asked him to do for months now.
Im a bit confused really, seems a case of one off small effort by @SirSickSik , against repeated effort by @johannes or I ( to keep merging the branches) and users copying files around...
fyi, unfortunately this merge cant be done automatically, as it it fails, it could potentially leave 1.0.11 in a 'bad state', which would then affect all users on the released version (1.0.11), so this is not really an option.
does raise the question of what we do with upgrades though, if some users can't move away from test versions, what do I do when we have 1.0.11 to 1.0.12? where its entirely reasonable for someone to stay on 1.0.11 as its released.
EDIT: oops, sorry a bit off-topic, we should probably discuss this elsewhere, when we get close to 1.0.12
