Hey,
Sorry for taking almost a year to come back to you here but I've just been trying to get my axoloti working again and I'm still having the same issues.
The messages I get in the log screen are below, I'm opening one of the demo patches from library so I don't believe its the patch that should be causing any issues.
Any help would be greatly appreciated!
"Link to firmware CRC CDEEEFDA
Axoloti version : 2.0.0-0-g88b60fe build time : 18/12/2019 02:50:06 CET
Status: factory (2.0.0,anon) : OK ( 2.0.0,clean )
Status : home : OK
Status: community (2.0.0,anon) : OK ( 2.0.0,clean )
'mode' is not recognized as an internal or external command,
operable program or batch file.
search path : C:\Users\dango\Documents\axoloti-2.0.0\axoloti-factory\objects
search path : C:\Users\dango\Documents\axoloti-2.0.0\objects
search path : C:\Users\dango\Documents\axoloti-2.0.0\axoloti-contrib\objects
finished loading objects
USB device found
connected
Authentic Axoloti Core
Firmware version: 2.0.0.0, crc=0xCDEEEFDA
Generate code complete
Compiling patch failed
Compiling patch failed"
