Patch Won't Go Live
#21
Thanks, I'll try this when I get home from work.
#22
I've flashed firmware version 1.0.0.1 onto my board and reinstalled that version of Axoloti.
However I still have the same issue I used to have when I click the live button and it just unchecks itself and the patcher stays the same colour, I've included the messages from the log screen below.
"Done uploading patch
Starting patch...
Done starting patch
Start locking
Done locking
Disconnect request
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
Generate code complete
Start compiling patch
The screen cannot be set to the number of lines and columns specified.
Done compiling patch
Start uploading patch
bin path: C:\Users\dango\Documents\axoloti\build\xpatch.bin
block uploaded @ 0x20011000 length 7408
Starting patch...
Done starting patch
Start locking
Done locking"
#23
can you try and startup with s2 pressed? that should prevent any startup patches to run. i had a couple of weird errors when a bogus startup patch was on the axoloti.
#24
Sorry to continue to be annoying here, but can you say where the s2 button is?
Was just looking and can’t seem to locate it.
#25
There are 2 small buttons next to the MIDI ports, they are labeled on the bottom of the board.
#26
Thanks for clarifying, I've tried starting up with s2 pressed repeatedly now and unfortunately I am still having the same issue. I am holding s2 prior to powering up the board as the user guide states to so I assume I am doing this correctly.
Has anyone got any more ideas?
#27
can you program a simple patch that just outputs a tone and test if it runs on the board?
maybe just the patcher side is broken
#28
I've been using the first tutorial patch in the library which just outputs a sine tone to test it previously.
If memory serves it always that patch always used to output sound for me before I had this issue.
#29
Anyone else got any ideas here?
#30
Just bumping this thread, my Axoloti is still gathering dust on my desk so would be great to find a solution!
#31
Do you have another computer to try it on, might seem like an odd suggestion and probably a long shot, but a long while ago when I first started to use Axo, I was running the patcher on two different versions of OSX, and couldn't connect at all on my music machine, and went through all of the suggestions for pressing S2 and putting it into DFU mode, the issue was solved when I used my day to day computer with a different os and managed to get it into DFU mode, then I did a clean install on the mac that wouldn't connect.....
Like I say a long shot also (I'm sure you may have already done this) different usb cable, the micro usb is fraught with connection problems, I use a magnetic cable now so that I'm not constantly plugging and unplugging the micro usb connector
#32
yeah especially with going back and forth with the complicated 2.0 install i would definitely recommend to try the board on a different computer with a fresh axoloti 1 install. easiest way to trouble shoot whether its the board or the software.
#33
Thanks, I’ll try taking it into work or using my girlfriends laptop and see if I have any luck with that.
