Anyone have ideas as to how to achieve asimilar effect as the freeze delay on the octatrack? Its great for momentary stutter and glitch effects
Octatrack freeze delay?
jaffasplaffa
Thats pretty simple.
For a normal delay, the source is fed to the input of the delay, along with the feedback.
When you turn on the freeze mode you have to stop any source being send to the input and only feed the feedback to the input.
That's basically all you have to do, make a bypass switch for the source input, so the delay buffer is not fed any new material, only the feedback signal, as long as the freeze mode is active.
jaffasplaffa
Ps. Maybe if in freeze mode, you also have to set feedback to 100%. I don't remember atm.....
