Novation launchpad as drum sequencer
is it possible to use launchpad as 8 track 8 note real time drum sequencer?
Check out the patches of Mattilyn Mattroe
https://sebiik.github.io/community.axoloti.com.backup/t/weird-little-note-repeat-style-launchpad-sequencer/5620 and https://sebiik.github.io/community.axoloti.com.backup/t/ableton-session-view-style-5-track-midi-sequencer/5790
He has the makings of what you are looking for and more besides
Thank, I will check this threds
Here's a custom firmware sequencer project for Launchpad Pro: http://faqtor.fr/launchpadpro.html
You might not even need to use axo for the sequencer part!
Sounds wondefull, now I need to have a launchpad pro :). Do you think will they do the same with launchpad mini?
I came up with this simple 16 step drum sequencer launchpad patch. Play is the top right button, top left button saves to sd card, grid is 16 step toggles x4. I've put comments in to explain the objects.
launchpad 16 step drum sequencer.axp (16.0 KB)
