Looks interesting . will dive into playing with this next chance I get.
Module requests
Since there are currently no layout options for object/subpatch controls, you're stuck with vertical layout.
you can also have a horizontal layout, that was my first try for the control modules, but then you have that big "empty" space on top of the module where the ins and outs are.. that's why I returned to verticle positioning and grouped the controls together per channel
i like the per channel thing, it looks nice and tidy.
i also really like the way it allows you to have as many or as few channels as you want.
I'm just thinking I'll go a bit further with that... would be nice to be able to set how many channels are actually being used.. so they don't need processing power if not used..
try out my morphor, sculptor and table oscillators
4-voice morphing table oscillator coming up! (in the sense of the polyOsc I made this week)
A big chunk of the fun patching with axoloti for a hardware box, is trying to minimise the amount of controls and fine tuning them. While trying to make a "one knob to many knobs", I found it quite frustrating to calculate the right offset and scale for my signal conversions. So this is my dreamed object :
something like @DrJustice math/offset_scale object but with a kind of limiter too (like @janvantomme math/constrain )
you have one inlet, for your signal : x
and one outlet : X
2 dials for the input limits : a and b
and 2 dials for the output limits : A and B
if x =< a then X=A
if x => b then X=B
it would save a lot of time and allow just a fraction of a value to control a certain range of an other value
So if anyone has the time / envy for such an object, I'll be very thankful
Otherwise, my other dream would be to have an adaptation of the BBcut live algorithmic breakbeats module.
Mdsp @ Smartelectronix did a great vst adaptation for it some years ago : livecut .
I really don't know if it's feasible, difficult or too power demanding, but it would be a great addition to the glitchy module list (and finaly be quite close to @JeromeB sample/beatslicer object)
I'm looking into this, but I think many objects already have a parameter for offset corresponding to an inlet, which makes the output shifting redundant. So I propose this variation:
and one outlet : X
if x =< a then X=0
if x => b then X=64
I think it leads to better "partitioning" if you want to combine multiple inputs to a certain output range, you can use a mixer, connect a "ctrl/dial p" to the bus inlet of a mix for bias if needed. Or a math/*c for a single input when an offset parameter would be redundant.
Would that address your needs?
@johannes Yes I think it would be sufficient and I understand your solution very well. Thanks for looking into it.
just made a new module
"scaleInOut"
scales the incoming signal to the min/max values set on the module. Clips if incoming signal goes beyond limits set by the inMin and inMax parameters and scales it to the range set by the outMin and outMax parameters.
Id like to request a complex "macro oscillator" like Braids. Or digital sound source as they also call it. Someting that can really change the sound drastically and give a lot of different timbres with just a few knobs.
ah, you're just too late with your request...
fixed it yesterday.. check out the rubsik, rubisikTable and Ruby oscillators
and of course, dont forget "TheCreator" module (oscillator folder) to make a 1024 waveform wavetable in 30 seconds
Cool, will look into the rub-oscs.
I am pretty much covered on the wavetable side already, but yeah, gonna test it anyway.
Hey
I would like to request a mixer. I made one as subpatch, but I am confident that it is way more DSP friendly to build a custom object for it. Pictures and patch below. This one got a build in send effect, that is what the output is for. Dunno if possible to make that.
mixer.axp (16.5 KB)
I've just been working on a new "desktop mixer" with independent modules for the controls (so the mixer module won't be huge)
as of your request, I just added 2 send outputs
it also features panning for each channel and main volume output controls for the stereo and send outputs on the mixer-core.
Hi. A request:)
A sampler module. I have a bunch of loopable jupiter 4 samples and i would like to make a virtual sample based model.
-Load X amount of samples into the module.
-Set keyspan for each sample.
-Loop mode on/off
-Loop point adjustment.
- A "nice to have" would be to be able to adjust loop mode= Reverse/back& forth etc.
-a "max" voice control (to mimick old 4 voice analog polys)
-Should have a FM input. Maybe even even per voice(?)
pfieuw.. been trying to see what I could change to get a bit further with the wave player, but even the simplest wave player won't work without disconnecting and having to re-connect every time,, I'm afraid this is above my head, as this is more about hard-core coding then synthesis modeling and sequencer-funky-things. Maybe in the future, but atm I'm not able to do such in-depth-getting-into-the-module-and-sucking-whatever-kind-of-piece-of-information-out-of-it kind of coding...
This also happens to the factory versions. almost every patch that I use waveplayer objects in disconnects when I make the patch "unlive".
@johannes do you have any idea why that happens?
Ill see if I can dig up a patch that does this and post it for analysis.
