Hi.
I would like to use my Axoloti to sync my analog delay pedal to the midi clock coming from my Digitakt. The delay pedal (DOD Rubberneck) has a tap tempo input that only needs to be operated with a momentary switch.
How would I go about mimicking the press of a momentary switch from the Axoloti?
So far I would suggest a Midi Clock object connected to a digital pin out object. The output of the digital pin would the be connected to the actual delay pedal tap tempo input.
Does that make sense?
Best
