How is Axoloti.exe generated?
windows
I'm not sure where to look in the codebase, so could anyone kindly advise how Axoloti.exe is generated on Windows? I ask because it seems related to a crashing issue documented here: https://sebiik.github.io/community.axoloti.com.backup/t/axoloti-patcher-crashes-to-desktop-on-invoking-file-dialog/3880/2
cheers and keep writing noise-making code!
make deploy
we use javafx to wrap the jar and we have ever since version 1.0.0, without issue :slight_smile:
ive just responded to the other thread, as mentioned there, it works perfectly fine on my windows 10 64 bit laptop, so the issue needs to be drilled down a bit more.
(quite a few Axoloti users are running win 10, so if only 2-3 users report such a 'serious issue', its likely its something a bit more subtle than just win10/64bit)
Axoloti patcher crashes to desktop on invoking file dialog
