Forum profile: @hohum
Contributor prefix: hohum
The team at Hohum lab has worked on designing and building a case with expansion board for the Axoloti Core, called the Axoctrl. The Axoctrl adds controls, ports and a display to the Axoloti Core, which should make prototyping and playing with the Axoloti Core a lot easier. And protect your board from dust and scratches!
To make it easy to work with the Axoctrl, we've developed some patches and objects that provide some basic functionality for the Axoctrl.
The main objects will make it easy to work with all inputs and outputs on the board, while also providing features such as patch switching, audio waveform on display and built-in LFO.
The objects and patches can now be found at https://github.com/berendkleinhaneveld/hohum-axoctrl
In order for these patches to run, a fix to the objects/patch/outlet string.axo object is needed, otherwise you'll encounter a compilation error. See here for details on how to fix it (quite simple!).
we've been quite busy in the last months but we're getting back in track! We will add a "contributor request" on the new website so developers can submit their interest and ask for a testing board. Thanks for the suggestion.
