Hey!!
I hope you can help with
Just got the board, and follow the installation process, and when im ready to Patch it gives me this errors
Runtime directory is invalid:C:\Program Files (x86)\axoloti_runtime, is the runtime installed? correctly?
USB device found
not accesseable : -12
USB device found
connected
Authentic Axoloti Core
search path : objects
Firmware version: 1.0.0.1, crc=0xFB45859B, entrypoint=0x20011000
finished loading objects
And when press live button this
USB device found
USB device found
connected
upgraded object by SHA : math/*c
Generate code complete
Start compiling patch
"make" no se reconoce como un comando interno o externo,
programa o archivo por lotes ejecutable.
Compiling patch failed ( C:\Program Files (x86)\Axoloti\app\patches\tutorials\01_sine_oscillator.axp )
Thanks
- then simply you will not be able to install any subsequent new hardware. My relationship with Microsoft died swiftly with the demise of Windows XP.
