Ok, so got 2 versions running at the same time and I have selected device for both Axolotis in each of the 2 axoloti patchers. The first one connects and goes live. Second one does connects but does not go live and I get this error.
Generate code complete
Start creating directory on sdcard : /Mixers Send Out
creating dir: /Mixers Send Out
Done creating directory
Changing working directory on sdcard : /Mixers Send Out
Change working directory: /Mixers Send Out
file error: FR_DENIED, filename:"/Mixers Send Out"
file error: FR_NO_PATH, filename:"/Mixers Send Out"
Start compiling patch
BDIR = /Users/jakobskouborg/Documents/axoloti/build
Makefile.patch:35: /Applications/Axoloti: No such file or directory
FIRMWARE = .
Makefile.patch:35: copy.app/Contents/Java/chibios/boards/ST_STM32F4_DISCOVERY/board.mk: No such file or directory
Makefile.patch:36: /Applications/Axoloti: No such file or directory
Makefile.patch:36: copy.app/Contents/Java/chibios/os/hal/platforms/STM32F4xx/platform.mk: No such file or directory
Makefile.patch:37: /Applications/Axoloti: No such file or directory
Makefile.patch:37: copy.app/Contents/Java/chibios/os/hal/hal.mk: No such file or directory
Makefile.patch:38: /Applications/Axoloti: No such file or directory
Makefile.patch:38: copy.app/Contents/Java/chibios/os/ports/GCC/ARMCMx/STM32F4xx/port.mk: No such file or directory
Makefile.patch:39: /Applications/Axoloti: No such file or directory
Makefile.patch:39: copy.app/Contents/Java/chibios/os/kernel/kernel.mk: No such file or directory
Makefile.patch:40: /Applications/Axoloti: No such file or directory
Makefile.patch:40: copy.app/Contents/Java/chibios/os/various/fatfs_bindings/fatfs.mk: No such file or directory
make: *** No rule to make target `copy.app/Contents/Java/chibios/os/various/fatfs_bindings/fatfs.mk'. Stop.
Compiling patch failed ( /Users/jakobskouborg/Documents/Axoloti OWN/Jaffy Jaf (1.0.11)/0. Favourites/Mixers/Mixers Send Out.axp )
@thetechnobear is this releated to what you mentioned about using terminal?
Could you explain it a bit further?
NOTE: For the second version of Axoloti I just copied the Axoloti app in applications so now I have 2 apps, one called Axoloti and another called Axoloti copy(this one also says "Axoloti developer").
Thanks
