Keyboard is good as a destination instrument... Huge user base.
But I want to make new instruments.
Still wood is good tho not just for hipsters
Editing patches axo/uModu/Reaktor style is best.
Having a hardcore community like Axo is bester.
some how (dont ask!), I now also have an Organelle
first impressions, its actually very good...
only played with the factory patches, which I must say, do sound excellent, and are really creative 10 out of 10!
what is excellent, and the primary reason I got it... is its a self contained box, you just power it up and off you go...
pure data, Im getting used to it - and decided, its not a big deal for me, if things get too complex I can just write a PD External and use C++ , so Im going to use PD mainly as glue, which has the benefit is the same PD externals I can use (different compile flags) inside Bela! (also on a rPI3)
p.s. I still find it easier to patch in Axoloti rather than PD... though granted there are thousands of PD externals out there.
connectivity, its great to be able to just chuck a wifi usb stick in, ssh into it, and transfer files etc.. also hubs work, and Im going to be trying other stuff .. but its great you dont have to connect anything!
(Ive yet to get my 7" touch screen working, but my portable keyboard worked out of the box)
code is open source, and its very simple C++ , so really easy to modify, already made a couple of small improvements ... couldn't resist
boot/shutdown time, is not bad (20 sec/6 sec respectively) , though of course, Id prefer it to be instant!
Its certainly not a replacement for either Axoloti or Bela, both are much better for building instruments (and I use Axoloti as my 'swiss army knife' for midi/fx as well) , and there latency is much better (though Ive not tested Organelle yet) - but Organelle is fun to sit with on the couch, and just have play, or to attach to you mixers 'send' and randomly throwing audio into various patches.
(I guess, Im using it a bit like some may use the OP-1, which I like the portability of, but was not so keen on is functionality... though I do totally respect it is a fantastic instrument)
oh, and it works as a small midi keyboard (albeit without velocity!) which is something I needed.
anyway, Im glad Ive got it... it will be good friends with my Belas and Axolotis.
please provide some latency measurements when you get the chance! so we can settle this once and for all
will do, though at the moment Im either spending my time just playing it ... or trying to work out what makes it tick (software, codec, arch linux setup etc)
latency will be a bit tricky.
guess the best is to measure RTT on ADC<- PD -> DAC as thats what most users are using it for, when using effects.
then there is midi latency, I could do an RTT, but thats fraught with issues e.g. latency in the loopback device, the connection method (e.g. if I use a USB midi din converter that is going to be slower than USB to USB) - so not really sure the best way to do this, to get a fair measurement.
what I would be more interested in is jitter for midi.
... and of course, using PD, would not be as quick as using alsa directly from C++ etc, so not strictly a test of the hardware, rather the normal 'users experience'
I wil say so far, as an instrument it seems fine... and even when using it as a send effect it sounded good... now that may be as i was tending to play with reverbs/delays so of course, latency is not a big issue....
(and of course with FX, you can select wet/dry... so I can select full wet, and let the mixer give me the dry mix)
i would be most interested in analog in to analog out with a simple adc~ dac~ connection in puredata. should be fairly easy to measure and i can get a pretty good idea from there
midi in to audio out depends on a lot of stuff, that is true. maybe usb midi (not din) with a simple synth patch in puredata to analog out. do you have an oscilloscope? that would make things much easier.
thanks for investigating and looking forward to the results, wondering if my friend got his measurements right!
Wuhuuuu, FINALLY I got my hands on a second hand Organelle
Just waiting to finalize last step of the deal..... Excited
cool, if your getting familiar with PD , I think you'll like it...
its also getting a bit of a buzz around it - very different from Axoloti, I think a much small percentage of the community make patches... and just use them, but there getting a good supply , and many are well thought out.
as I said, I think its strength is immediacy, because the form factor is a given... patches have to work with the hardware that is there, so they are always 'finished' and useable.
of course, if your in to PD etc, then you can take them and tweak them, or use bits for other projects... its fun
oh @jaffasplaffa , buy a small wifi dongle.. makes transferring patches etc, much easier.
(id also recommend at some point getting a larger sd card (8 or 16gb), see my posts on using sdcard rather than usb stick!)
Yay, I payed for it now, so now it is just the waiting game..... I hate that....
I almost havent touched the Axoloti for the last couple of months, have been learning PD, so starting to have a decent library for PD and can soon start to make some music. But I guess I need to do some adaptions top make them run on Organelle now, hehe
yeah, that is next. Finding out how to optimize it and make it run as smooth as possible
MOD NOTE: Ive moved this from a thread discussing audio effects on Axoloti, as it starts venturing into alternatives including Organelle - TB
On what hardware though?
Pure Data can run on many different platform, like Win, Osx, Linux, etc.
So it is basically up to you what you want to run it on. There are also dedicated devices that runs Pure Data, like Organelle. Just got an Organelle a few days ago and on this I can finally make full arrangements on a single device. Couldnt do that on Axoloti, so I am really happy about this.
Pure Data can also run on a Raspberry Pi if you like. So it is really up to the user and be creative and build what you want
$495.00, no thanks
doesn't look like pro audio gear either.
• Sampling Rate: 44.1kHz; 16-bit (In & Out)
• 2x ¼" Mono Sound Output Jacks (L & R channels)
A toy, not even as good as axo.
Massively overpriced, not flexible, wouldn't use it if given one.
I didnt pay that for mine. Yes I think that is a bit too expensive.
Sound quality is better than Axoloti. And sonic capabilities are a lot greater too.
Wrong. As it runs Pure Data it can do a lot more than Axoloti can, cause Pure Data is many years old and have been developed for a lot longer time than Axo has.
Yeah, some things take time. As I said, the things I want to do, cannot be done on Axoloti because of its low DSP power. If Axoloti had a lot more power it would be great, but it doesnt, so for me personally it is a natural progression to move on to something that can do the things I want to do. I think that is a fair and a personally choice.
I do think Axo has been a big learning experience. But I just feel like I wont learn much more if I stay on this platform, so of course I am going to try something new
lol, sorry 16 bit 44.1k is not better sound than Axo, what are you running it into? do you have decent studio monitors good enough to compare sound quality somewhat objectively?
The organelle would not suit my needs even if it were cheap.
It runs linux and linux is not a real time OS, and is a massive unnecessary processing and maintenance overhead.
Just a 5 second look at the thing tells me it's not what I want, Axo, for all it's faults, is much more flexible and extendable
I had a brief look at pure data, it's even uglier looking than Axo, nowhere near as intuitive to use and doesn't appear to have a fraction of the available modules for Axo. Pass.
Appears you could build your own with an RPI and save $495, the following allthough for guitar seams very similar approach.
16 bit 44.1 is more than enough.
I have got an couple of Axolotis and I have had them for a few years now. I have also got an Organelle. And my opinion based on listening tests and actually listening to both devices, the sound in Organelle is of better quality. Have you tested them next to each other?
Another ting is how good an audio device sounds isnt necessarily only reliant on the sample and bit rate, but probably more on the quality of the dac being used. There are many things playing a role here, so saying 16 48 is better than 16 44,1 is not really a 100% true.
I have not said it was intuitiv, I said that Pure Data is reliant on the computer you run it ons processor. Hence you can load a lot more, hence you can go deeper and explore synthesis like FFT and phase vocoding. You can't do that in Axoloti cause it doesnt have the amount of DSP or memory needed. Again, I am just saying my needs have exceedes what is possible with Axoloti and therefor need to try something else. And PD can, from what I learned by now, do anything I want. It might look "simple" but it is super complex and you need to work for it
@Gavin
I am happy, I payed around 340 dollars for mine
But saying that one saves a lot of money is not always entirely true. Cause most of the times you need a lot more than just the Pi3 to make a sound device. For example an audio hat of good quality easily cost 100-200$. You can get a lot cheaper audio interfaces so there is something to save there.. But then if you also need a bunch of knobs too and other things, like display if you wan to interact with it without a regular computer display. Eventually the PI3 build I was working on enden up costing more than I payed for the Organelle. So I put the Pi3 build on hold and instead bought the organelle. But still plan to make the Pi3 build later on.
