Ok I don't know how but the patcher is back.
I've followed thetechnobear's instruction here, https://sebiik.github.io/community.axoloti.com.backup/t/mac-software-no-menus-or-windows/366
so I deleted axoloti.prefs file and run this terminal code. First it didn't work but then it was back suddenly.
This is the code terminal got me in case you need it for debugging:
Simons-MBP:~ Simon$ /Applications/Axoloti.app/Contents/MacOS/Axoloti
Jan 16, 2016 1:03:35 AM axoloti.utils.Preferences LoadPreferences
SCHWERWIEGEND: null
javax.xml.stream.XMLStreamException: ParseError at [row,col]:[1,1]
Message: Vorzeitiges Dateiende.
    at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:596)
    at com.sun.xml.internal.stream.XMLEventReaderImpl.nextEvent(XMLEventReaderImpl.java:83)
    at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:110)
    at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:122)
    at org.simpleframework.xml.stream.StreamReader.next(StreamReader.java:94)
    at org.simpleframework.xml.stream.NodeReader.readElement(NodeReader.java:111)
    at org.simpleframework.xml.stream.NodeReader.readRoot(NodeReader.java:85)
    at org.simpleframework.xml.stream.NodeBuilder.read(NodeBuilder.java:84)
    at org.simpleframework.xml.stream.NodeBuilder.read(NodeBuilder.java:58)
    at axoloti.utils.Preferences.LoadPreferences(Preferences.java:168)
    at axoloti.Axoloti.initProperties(Axoloti.java:194)
    at axoloti.Axoloti.main(Axoloti.java:50)
Axoloti Directories:
Current = /Applications/Axoloti.app/Contents/Java
Jar = /Applications/Axoloti.app/Contents/Java
Release = /Applications/Axoloti.app/Contents/Java
Runtime = /Applications/axoloti_runtime
Firmware = /Applications/Axoloti.app/Contents/Java/firmware
AxolotiHome = /Users/Simon/Documents/axoloti
Jan 16, 2016 1:03:36 AM axoloti.utils.Preferences LoadPreferences
SCHWERWIEGEND: null
    at axoloti.MainFrame.(MainFrame.java:94)
    at axoloti.Axoloti$1.run(Axoloti.java:299)
    at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
Jan 16, 2016 1:03:36 AM axoloti.MainFrame updateLinkFirmwareID
INFORMATION: Link to firmware CRC 12D13CA6
Exception in thread "PingerThread" java.lang.NullPointerException
    at qcmds.QCmdProcessor$PeriodicPinger.run(QCmdProcessor.java:52)
    at axoloti.MainFrame.(MainFrame.java:215)
Jan 16, 2016 1:08:22 AM axoloti.MainFrame updateLinkFirmwareID
Jan 16, 2016 1:08:22 AM axoloti.object.AxoObjects$2 run
INFORMATION: search path : objects
Jan 16, 2016 1:08:22 AM axoloti.USBBulkConnection OpenDeviceHandle
INFORMATION: USB device found
Jan 16, 2016 1:08:22 AM axoloti.USBBulkConnection connect
SCHWERWIEGEND: connected
Jan 16, 2016 1:08:22 AM axoloti.USBBulkConnection processByte
INFORMATION: Firmware version: 1.0.0.1, crc=0x12D13CA6, entrypoint=0x20011000
Jan 16, 2016 1:08:23 AM axoloti.USBBulkConnection connect
INFORMATION: Authentic Axoloti Core
Jan 16, 2016 1:08:23 AM axoloti.USBBulkConnection$1 run
INFORMATION: Rx paramchange patch null0 134.217.727
INFORMATION: Rx paramchange patch null1 134.217.727
INFORMATION: Rx paramchange patch null2 134.217.727
INFORMATION: Rx paramchange patch null3 0
INFORMATION: Rx paramchange patch null4 0
INFORMATION: Rx paramchange patch null5 37.748.736
INFORMATION: Rx paramchange patch null6 67.108.864
INFORMATION: Rx paramchange patch null7 67.108.864
INFORMATION: Rx paramchange patch null8 134.217.727
INFORMATION: Rx paramchange patch null9 0
INFORMATION: Rx paramchange patch null10 42.991.616
INFORMATION: Rx paramchange patch null11 35.651.584
INFORMATION: Rx paramchange patch null12 -134.217.728
INFORMATION: Rx paramchange patch null13 -18.874.368
INFORMATION: Rx paramchange patch null14 44.040.192
INFORMATION: Rx paramchange patch null15 46.137.344
INFORMATION: Rx paramchange patch null16 -69.206.016
INFORMATION: Rx paramchange patch null17 -134.217.728
INFORMATION: Rx paramchange patch null18 -27.262.976
INFORMATION: Rx paramchange patch null19 -134.217.728
INFORMATION: Rx paramchange patch null20 0
INFORMATION: Rx paramchange patch null21 13.631.488
INFORMATION: Rx paramchange patch null22 12.582.912
INFORMATION: Rx paramchange patch null23 14.680.064
INFORMATION: Rx paramchange patch null24 134.217.727
Jan 16, 2016 1:08:23 AM axoloti.object.AxoObjects$2 run
INFORMATION: finished loading objects
INFORMATION: Rx paramchange patch null25 56.623.104
INFORMATION: Rx paramchange patch null26 -134.217.728
INFORMATION: Rx paramchange patch null27 -92.274.688
INFORMATION: Rx paramchange patch null28 42.991.616
INFORMATION: Rx paramchange patch null29 -134.217.728
INFORMATION: Rx paramchange patch null30 -39.845.888
INFORMATION: Rx paramchange patch null31 0
INFORMATION: Rx paramchange patch null32 77.594.624
INFORMATION: Rx paramchange patch null33 0
INFORMATION: Rx paramchange patch null34 18.874.368
INFORMATION: Rx paramchange patch null35 18.874.368
INFORMATION: Rx paramchange patch null36 18.874.368
INFORMATION: Rx paramchange patch null37 0
INFORMATION: Rx paramchange patch null38 51.380.224
INFORMATION: Rx paramchange patch null39 -75.497.472
INFORMATION: Rx paramchange patch null40 -134.217.728
INFORMATION: Rx paramchange patch null41 -20.971.520
INFORMATION: Rx paramchange patch null42 67.108.864
INFORMATION: Rx paramchange patch null43 75.497.472
INFORMATION: Rx paramchange patch null44 134.217.728
INFORMATION: Rx paramchange patch null45 134.217.728
INFORMATION: Rx paramchange patch null46 0
INFORMATION: Rx paramchange patch null47 71.303.168
INFORMATION: Rx paramchange patch null48 0
INFORMATION: Rx paramchange patch null49 -134.217.728
INFORMATION: Rx paramchange patch null50 2.097.152
INFORMATION: Rx paramchange patch null51 -58.720.256
INFORMATION: Rx paramchange patch null52 68.157.440
INFORMATION: Rx paramchange patch null53 -127.926.272
INFORMATION: Rx paramchange patch null54 60.817.408
INFORMATION: Rx paramchange patch null55 58.720.256
INFORMATION: Rx paramchange patch null56 67.108.864
INFORMATION: Rx paramchange patch null57 0
INFORMATION: Rx paramchange patch null58 71.303.168
INFORMATION: Rx paramchange patch null59 0
INFORMATION: Rx paramchange patch null60 134.217.728
INFORMATION: Rx paramchange patch null61 0
INFORMATION: Rx paramchange patch null62 134.217.728
INFORMATION: Rx paramchange patch null63 -134.217.728
INFORMATION: Rx paramchange patch null64 -25.165.824
INFORMATION: Rx paramchange patch null65 87.031.808
INFORMATION: Rx paramchange patch null66 0
INFORMATION: Rx paramchange patch null67 0
INFORMATION: Rx paramchange patch null68 0
INFORMATION: Rx paramchange patch null69 -50.331.648
Jan 16, 2016 1:11:34 AM axoloti.utils.Preferences SavePrefs
INFORMATION: Saving preferences...
INFORMATION: preferences path : /Users/Simon/Documents/axoloti/axoloti.prefs
restored from UUID:midi/in/keyb note
restored from UUID:mix/mix 8
restored from UUID:filter/multimode svf m
restored from UUID:audio/out stereo
restored from UUID:mix/mix 1
restored from UUID:gain/vca
restored from UUID:wave/play fn stereo
restored from UUID:env/d
restored from UUID:env/ad
restored from UUID:mix/mix 2
restored from UUID:osc/sine
restored from UUID:mix/mix 3
restored from UUID:filter/vcf3
restored from UUID:math/+c
Obj added keyb_5
Obj added mix_3
Obj added multimode_1
displays.DisplayFrac32VU@5f150feb
displays.DisplayFrac32VU@604ca12c
Obj added out_1
Obj added mix_1
Obj added vca_1
Obj added play_3
Obj added d_1
Obj added ad_2
Obj added mix_4
Obj added sine_1
Obj added ad_3
Obj added keyb_4
Obj added vca_2
Obj added multimode_2
Obj added mix_2
Obj added play_1
Obj added play_4
Obj added play_5
Obj added keyb_3
Obj added vcf3_1
Obj added play_2
Obj added keyb_7
Obj added vca_3
Obj added d_2
Obj added vca_4
Obj added d_3
Obj added play_6
Obj added play_7
Obj added keyb_6
Obj added keyb_2
Obj added +c_3
Obj added keyb_8
Obj added vca_5
Obj added d_4
Obj added vca_6
Obj added d_5
Obj added vca_11
Jan 16, 2016 1:11:37 AM axoloti.Patch WriteCode
INFORMATION: Generate code complete
Jan 16, 2016 1:11:37 AM qcmds.QCmdShellTask$StreamHandlerThread run
INFORMATION: Compiling patch... with /Applications/Axoloti.app/Contents/Java/firmware
INFORMATION: BDIR = /Users/Simon/Documents/axoloti/build
INFORMATION: FIRMWARE = .
INFORMATION: Build precompiled header
INFORMATION: arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -Wunused-parameter -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -I/Applications/Axoloti.app/Contents/Java/CMSIS/Include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx/CMSIS/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/kernel/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/GPIOv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/I2Cv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/OTGv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/RTCv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/SPIv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/TIMv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/USARTv1 -I/Applications/Axoloti.app/Contents/Java/chibios/boards/ST_STM32F4_DISCOVERY -I/Applications/Axoloti.app/Contents/Java/chibios/ext/fatfs/src -I. -I/Applications/Axoloti.app/Contents/Java/chibios -Winvalid-pch -MD -MP -c ./xpatch.h  -o /Users/Simon/Documents/axoloti/build/xpatch.h.gch
Jan 16, 2016 1:11:38 AM qcmds.QCmdProcessor$4 run
INFORMATION: Start compiling patch
Jan 16, 2016 1:11:38 AM qcmds.QCmdShellTask$StreamHandlerThread run
INFORMATION: RM
INFORMATION: rm -f /Users/Simon/Documents/axoloti/build/xpatch.o /Users/Simon/Documents/axoloti/build/xpatch.elf /Users/Simon/Documents/axoloti/build/xpatch.bin /Users/Simon/Documents/axoloti/build/xpatch.d /Users/Simon/Documents/axoloti/build/xpatch.map /Users/Simon/Documents/axoloti/build/xpatch.lst
INFORMATION: APP
INFORMATION: arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -Wunused-parameter -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -H -I/Applications/Axoloti.app/Contents/Java/CMSIS/Include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx/CMSIS/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/kernel/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/GPIOv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/I2Cv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/OTGv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/RTCv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/SPIv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/TIMv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/USARTv1 -I/Applications/Axoloti.app/Contents/Java/chibios/boards/ST_STM32F4_DISCOVERY -I/Applications/Axoloti.app/Contents/Java/chibios/ext/fatfs/src -I. -I/Applications/Axoloti.app/Contents/Java/chibios -Winvalid-pch -MD -MP --include /Users/Simon/Documents/axoloti/build/xpatch.h -c /Users/Simon/Documents/axoloti/build/xpatch.cpp -o /Users/Simon/Documents/axoloti/build/xpatch.o
INFORMATION: ! /Users/Simon/Documents/axoloti/build/xpatch.h.gch
INFORMATION: . /Applications/Axoloti.app/Contents/Java/chibios/ext/fatfs/src/ff.h
INFORMATION: . /Applications/Axoloti.app/Contents/Java/objects/wave/streamer.h
Jan 16, 2016 1:11:39 AM qcmds.QCmdShellTask$StreamHandlerThread run
INFORMATION: Multiple include guards may be useful for:
INFORMATION: /Applications/Axoloti.app/Contents/Java/objects/wave/streamer.h
INFORMATION: LINK
INFORMATION: arm-none-eabi-gcc -nostartfiles -Tramlink.ld -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb  -mno-thumb-interwork /Users/Simon/Documents/axoloti/build/xpatch.o -Wl,-Map=/Users/Simon/Documents/axoloti/build/xpatch.map,--cref,--just-symbols=./build/axoloti.elf -o /Users/Simon/Documents/axoloti/build/xpatch.elf
INFORMATION: BIN
INFORMATION: arm-none-eabi-objcopy -O binary /Users/Simon/Documents/axoloti/build/xpatch.elf /Users/Simon/Documents/axoloti/build/xpatch.bin
Jan 16, 2016 1:11:39 AM qcmds.QCmdProcessor$4 run
INFORMATION: Done compiling patch
Jan 16, 2016 1:11:39 AM qcmds.QCmdUploadPatch Do
INFORMATION: bin path: /Users/Simon/Documents/axoloti/build/xpatch.bin
INFORMATION: Start uploading patch
Jan 16, 2016 1:11:39 AM axoloti.USBBulkConnection UploadFragment
INFORMATION: block uploaded @ 0x20011000 length 15688
INFORMATION: Done uploading patch
INFORMATION: Start starting patch
INFORMATION: Done starting patch
INFORMATION: Start locking
INFORMATION: Done locking
Simons-MBP:~ Simon$
