Thank you Technobear. Running the command from terminal i get this output:
Oct 22, 2015 2:14:57 PM axoloti.utils.Preferences LoadPreferences
GRAVE: null
javax.xml.stream.XMLStreamException: ParseError at [row,col]:[1,1]
Message: Fine del file anticipata.
at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:601)
at com.sun.xml.internal.stream.XMLEventReaderImpl.nextEvent(XMLEventReaderImpl.java:83)
at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:110)
at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:122)
at org.simpleframework.xml.stream.StreamReader.next(StreamReader.java:94)
at org.simpleframework.xml.stream.NodeReader.readElement(NodeReader.java:111)
at org.simpleframework.xml.stream.NodeReader.readRoot(NodeReader.java:85)
at org.simpleframework.xml.stream.NodeBuilder.read(NodeBuilder.java:84)
at org.simpleframework.xml.stream.NodeBuilder.read(NodeBuilder.java:58)
at axoloti.utils.Preferences.LoadPreferences(Preferences.java:149)
at axoloti.Axoloti.initProperties(Axoloti.java:194)
at axoloti.Axoloti.main(Axoloti.java:50)
Axoloti Directories:
Current = /Applications/Axoloti.app/Contents/Java
Jar = /Applications/Axoloti.app/Contents/Java
Release = /Applications/Axoloti.app/Contents/Java
Runtime = /Applications/axoloti_runtime
Firmware = /Applications/Axoloti.app/Contents/Java/firmware
AxolotiHome = /Users/fabriziolugli/Documents/axoloti
Oct 22, 2015 2:14:58 PM axoloti.utils.Preferences LoadPreferences
GRAVE: null
at axoloti.MainFrame.(MainFrame.java:91)
at axoloti.Axoloti$1.run(Axoloti.java:299)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
Oct 22 14:15:02 fabrizio-luglis-computer.local Axoloti[293] : CGContextGetCTM: invalid context 0x0
Oct 22 14:15:02 fabrizio-luglis-computer.local Axoloti[293] : CGContextSetBaseCTM: invalid context 0x0
Oct 22, 2015 2:15:02 PM axoloti.MainFrame updateLinkFirmwareID
INFORMAZIONI: Link to firmware CRC A4AA9FE1
Exception in thread "PingerThread" java.lang.NullPointerException
at qcmds.QCmdProcessor$PeriodicPinger.run(QCmdProcessor.java:52)
Oct 22 14:15:03 fabrizio-luglis-computer.local Axoloti[293] : CGContextGetCTM: invalid context 0x0
Oct 22 14:15:03 fabrizio-luglis-computer.local Axoloti[293] : CGContextSetBaseCTM: invalid context 0x0
Oct 22 14:15:04 fabrizio-luglis-computer.local Axoloti[293] : CGContextGetCTM: invalid context 0x0
Oct 22 14:15:04 fabrizio-luglis-computer.local Axoloti[293] : CGContextSetBaseCTM: invalid context 0x0
at axoloti.MainFrame.(MainFrame.java:204)
The computer is a white Macbook from 2007 with 2 Ghz Intel Core 2 Duo
Mac OS X version is 10.7.5
Axoloti version is 1.0.3
axoloti.prefs is 0 bytes. I have removed it.
Axoloti is now starting. I don't have the board with me now. As soon as I can try it I will let you know if the issue is completely sorted.
