I tried 10k and 220ohm resistors but i didn't notice any difference
Can I make cv inputs with vactrols?
well, the range will be approximately the same. what changes is the curve of the signal. with the fixed resitor to VDD and your LDR you are forming a voltage divider. if you lower the resistance of the fixed resistor, the signal will stay longer near VDD, will hit half VDD when the LDR is equal to the fixed resistor and will go to zero when the LDR resistance approaches zero ohm. if you make the fixed resistor higher in value, the VDD/2 point will be reached much earlier and more of the time is spent in the lower half. you can also try to make the fixed resitor 100k for example
So did anything go further with this vactrol pcb setup? I want to try this as well and would love to take the shortcut. Best regards
Jhw
I've tried this and it works greatly. I tested it connecting behringer neutron and CMOS 40106 oscillators. Disconecting whatever you put into CV in, you get the complete value of the pot.
You have to invert the signal with the object drj/math/inv_pos.
Here are som simple Vactrol to resistance circuits I grabbed off the web years ago. They can offer some ideas for all.
