Current Version
28 Aug 2016 - 1.0.11
more details here : https://sebiik.github.io/community.axoloti.com.backup/t/axoloti-release-1-0-11
https://github.com/axoloti/axoloti/releases/latest
(runtime is unchanged since version 1.0.2)
Pre-release
current pre-release available for testing: None
Note: if you are using a pre-release, please read the following post to understand what pre-releases are for, what to expect and what we expect.
Obtaining software
All software is available from: https://github.com/axoloti/axoloti/releases
LATEST RELEASE, The latest supported and stable version is clearly labeled, this is the version most people should use.
PRE RELEASE versions are current development versions, usually these are NOT supported, unless we explicitly detail them there as "release candidates", these are used when we want wider testing prior to a "public release", or to allow some users to test a feature in development. They should not be used for performance or as the basis for review.
(of course, you are free to play with these versions, but recognise its "work in progress" )
A new release will always contain changes to the application software (Axoloti) including UI / Firmware /Demo patches, and will need to be downloaded and installed on each new release.
The axoloti runtime contains fairly static elements including the cross-compiler we use. This may not change form release to release. If axoloti runtime has changed, and needs to be downloaded and re-installed, the release notes will indicate this.
Installation
Please read the following for information on installing on the supported platforms.
Support
If you have any issues downloading, installing or using the software, please make a post in the Helpdesk
