@krikor I’m looking into possibly getting one of these laser cut. What are those metallic looking clamps you seem to be using above the I/Os? Also any more photos from other angles?
Axocontrol Enclosure
It is just a reflection as some of the material I selected for the laser cut is a bit transparent.
I will try to post some more pictures later.
Hi all,
If you are thinking of making a case like the one shown,
@Krikor and you find it hard to find a place to be cut,
I have a Laser cutter, (in fact I sell acrylic enclosures for Axoloti, on eBay and Amazon
Now I'm waiting to receive an Axoloticontrol plate, which I kindly bought from Krikor, to create a new synth that I want to make ...
Also if you have some other design in DXF or SVG, you can send it to me to estimate the cost of cutting and shipping.
Thank's
@krikor the PCB arrived this morning. well packed.
Thanks very much!
Now I have to find the rest of the pieces !!
I'm gonna make a few mods to the enclosure file. the two screws on the back of the unit touch the 40 pin connector (no problem but it is not well aligned). Also the hole for the XY controller is a bit to the right up, I need to move it to the left down or just enlarge it a bit.
I gotta double check, but it should be good.
I won't have time until this weekend.
I'm gonna replace the file when done, I will indicate it.
Thank you so much for sharing this! I've just put it together, but I think I'm missing something to lock things in place, namely something which uses the middle holes and the cross shaped cuts. I'm completely new to diy, could you please tell me what to use with these?
I'm using all the default parts that came with the AxoControl - as you can see the buttons are sunk in, but I can live with that
Thank you!
Here is my custom case with Axocontrol and 1.3in LED integration, adapted from some of the STLs files found here. I also made tall button caps as most are not tall enough for this case.
@dborowik cool - how did you wire the oled? according to this post: https://sebiik.github.io/community.axoloti.com.backup/t/oled-screens-and-the-thonk-axocontrol-board/6428/5?u=moono this supposedly does not work ; )
