I modded the case designed by @janvantomme to include the AXOCONTROL board.
Boards 1&2 needs to be cut on 3mm material and board 3 on 1.6mm material.
I used 3 mm Acrylic GS and 1.6 mm Acrylic Two Color at FORMULOR.de in Germany.
It should cost around 40ā¬+extra shipping via this company.
New Corrected EPS Illustrator files, as on the precedent ones, the PS1 style pad hole was a bit too much to the center of the unit and the two lower back screw were touching the 40 pin connector.
K
