Hello -
Similar issue here. I cannot get the patcher to load / launch correctly. I've been using an older laptop until a few weeks ago, and now cannot install Axo on my new machine.
Windows 10
Tried current releases are well as older ones - no success.
1.0.12 (older rev)
User Library version mismatch, do you want to upgrade? This will stash any changes, and then reapply to new version. If not, then you will need to manually back up changes, and then sync libraries.
Click 'yes'
Dialog box:
Firmware CRC mismatch detected. Asks if I want to update firmware, tells me LEDs will blink (they do not)
unidentified header : 0x726F7841
AxoA
unidentified header : 0x72AxoT6F7841
AxoA
Firmware version: 2.0.0.0, crc=0xDAEFEECD, entrypoint=0x900E0208
Firmware CRC mismatch! Please flash the firmware first! Hardware firmware CRC = DAEFEECD <> Software CRC = E95BAC96
Firmware is newer than the software release,
firmware updatAxoTe will fail,
and connection will fail too.
You need to downAxoTgrade firmware via the rescue (DFU) method!
AxoTunidentified header : 0x796F7841
AxoA
Disconnect request
AxoTunidentified header : 0x726F7841
AxoA
Link to firmware CRC E95BAC96
OR
connected
Can't obtain signature, upgrade firmware?
search path : C:\Users\aliss\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\aliss\Documents\axoloti\objects
search path : C:\Users\aliss\Documents\axoloti\axoloti-contrib\objects
finished loading objects
AxoA
Disconnect request
AxoA
Start uploading firmware
Done uploading firmware
Start uploading patch
Done uploading patch
Start flashing...
flashing... (ready when the green LED is steady on)
But the LED never flashes, and the patcher window never provides further updates. It hangs there.
Any ideas? Suggestions?
