Xml parse errors after trying to copy an object
I was working to an object (with patch/object) and got to a pretty serious issue: after trying to make a copy of it (which was correct, C-wise, since the patch would compile), the patch started giving xml parse errors.
The object could not be copied, and apparently reloading the patch (which i did not save, by the way) gave the same error again.
I opened the patch with a text editor and found what caused the bug: grafted arrays.
I'll explain this better: the code contained something like this: ....array1[ array2[index]] ...
Those two square brackets caused the bug, since in the xml file, portions of code are delimited with [CDATA[]] tags.
Those two square brackets were causing the bug.
I solved the problem putting an empty comment between my two brackets, like this: ....array1[ array2[index] /**/] ...
the error message by the way was:
javax.xml.stream.XMLStreamException: ParseError at [row,col]:[514,71]
Message: Il contenuto degli elementi deve essere composto da dati o markup di caratteri con formato corretto.
at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:596)
at com.sun.xml.internal.stream.XMLEventReaderImpl.nextEvent(XMLEventReaderImpl.java:83)
at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:110)
at org.simpleframework.xml.stream.StreamReader.next(StreamReader.java:94)
at org.simpleframework.xml.stream.StreamReader.peek(StreamReader.java:77)
at org.simpleframework.xml.stream.NodeReader.readText(NodeReader.java:258)
at org.simpleframework.xml.stream.NodeReader.readValue(NodeReader.java:235)
at org.simpleframework.xml.stream.InputElement.getValue(InputElement.java:201)
at org.simpleframework.xml.core.Primitive.read(Primitive.java:163)
at org.simpleframework.xml.core.Primitive.readElement(Primitive.java:207)
at org.simpleframework.xml.core.Primitive.readElement(Primitive.java:189)
at org.simpleframework.xml.core.Primitive.read(Primitive.java:124)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:623)
at org.simpleframework.xml.core.Composite.readInstance(Composite.java:573)
at org.simpleframework.xml.core.Composite.readUnion(Composite.java:549)
at org.simpleframework.xml.core.Composite.readElement(Composite.java:532)
at org.simpleframework.xml.core.Composite.readElements(Composite.java:445)
at org.simpleframework.xml.core.Composite.access$400(Composite.java:59)
at org.simpleframework.xml.core.Composite$Builder.read(Composite.java:1383)
at org.simpleframework.xml.core.Composite.read(Composite.java:201)
at org.simpleframework.xml.core.Composite.read(Composite.java:148)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:190)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:167)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:144)
at org.simpleframework.xml.core.CompositeListUnion.readElement(CompositeListUnion.java:189)
at org.simpleframework.xml.core.CompositeListUnion.read(CompositeListUnion.java:162)
at org.simpleframework.xml.core.Variable$Adapter.read(Variable.java:482)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:613)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1003)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1025)
at axoloti.MainFrame.actionPerformed(MainFrame.java:1156)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.Component.processMouseEvent(Component.java:6535)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
