hello community,
i want your opinions about MIDI clock in the following setup:
1) 1st Axoloti as USB host
2) sequencer: Squarp Pyramid connected to the 1st Axoloti via USB
3) 2nd Axoloti with USB MIDI interface connected to it via USB.
all MIDI routing is done by 2nd Axoloti patch.
in particular, Pyramid MIDI output is routed as 3 physical MIDI ports (where 1st Axoloti acts as USB to MIDI).
other devices are synths and hardware MIDI controllers (no computers).
so, who of three (1st Axoloti, 2nd Axoloti, Pyramid) should be MIDI clock master and why?
in particular, i'm interested about things that might make jitter worse in such configuration, so should be avoided.
