I did see the topic on how to code for axoloti objects but I was totally lost on the terminology, as I really know literally nothing about coding. I can design analog eurorack modules on my protoboard, so I'm not dumb
Should I learn C? XML? csound? . It would be awesome if somebody linked me to step by step progressive learning stages, as I do intend on creating my own objects eventually.
What steps should a total beginner take to learn coding for objects?
Many have asked for this and wants this in here. Or at least a category where we "noobs" can discuss object coding with each other. We asked for a "coders" category, but developer doesnt seem interested in that. But I guess the more people asking for it, the more likely it is we get one eventually.
@johannes would you consider creating this category? If you are worried that it will bring you a lot of ekstra explaining, you could put a disclaimer saying that the developer doesnt participate in that specific category. It is just important that the information is easy to find.
steps id suggest
a) ensure your very familiar with patching axoloti
b) learn some basic C (lots of resources on the internet)
c) read a up on the basics of DSP, if your not familiar with it (http://www.dspguide.com/pdfbook.htm)
you can then start basic object creation with the object editor in Axoloti. (xml is not need initially)
obviously, baby steps, don't try anything too adventurous....
you can take a look at how existing objects are created as inspiration for your objects, or even as a starting point.
one thing that can be confusing is for efficiency , we use integer fixed point maths...
so you need good familiarity with Q Maths
for exporing DSP, you might initially also want to look for some Max/Pure data tutorials.
Just bare in mind, your dealing with a new language (C), a new environment... and if your not familiar with DSP programming, a new subject area... so it takes time, but its fun to make things go beep
also be warned, DSP programming is pretty maths intensive, so depending on your skills in this area, then you may want to avoid things like filters, reverbs etc
many = 2 people ... (or have i missed it, and its 3?)
anyway, Ive created here:
https://sebiik.github.io/community.axoloti.com.backup/c/axoobject-code
BUT... as I said when discussed before, Im not convinced its a topic that will get many posts... but lets give it a try, if its goes too off-topic, or doesnt attract enough posts, I'll merge them back into software, and delete the category
Cool, thanks guys. I'm quickly becoming quite familiar with patching in Axo, as a hardware modular designer/builder/user it is very intuitive to me. I will follow your suggested steps. I think the toughest for me will be the maths, even the wiki definition you linked is a bit cryptic for me, but I'll learn. Particularly what field of maths should I study for filter design and such? Calculus? Trig? All of it? Lol. Anyways, thanks again, and I'll be seeing you in the new coding section!
