Hi, I'm trying to optimally filter a sensor while I read it from my Axoloti. I was wondering what the effective impedance is on the ADCs so I can design the last stage of my output filter. Thank you
What is the ADC Input impedance for connecting sensors?
The short answer is 50kOhm, the long answer is found in the microcontroller datasheet, in section 6.3.21: 12-bit ADC characteristics.
For the long answer, there's the equation which involves F_ADC and k, the number of sampling periods in ADC_SMPR1. I was wondering if you could tell me those values? I appreciate the effort and I know players will be grateful for the extra sensitivity I can give them through knowing this.
ADC_SMPR1 is configured for 84 samples (in axoloti_board.c)
The ADC clock is the APB2 clock (84MHz) divided by 4 (ADC_CCR_ADCPRE_DIV4 in mcuconfig.h), so I believe F_ADC is 21MHz. So the datasheet equation tells, using quoted typical Cadc and Radc values:
Rain = (84-0.5)/(21M*4p*ln(2^(12+2)))-6k
... = 83.5/(84E-6 *ln(16384))-6k
... = 96436 ohm
Input resistance/impedance of GPIOs in AnalogIn Mode?
