Thanks, I appreciate that.
West Coast Synthesis - Demo
This is just amazing. Congrats for the hard work!
Edit: just watched the full video, nice demo as well!
WOW
Amazing, congratulations.
Not only your synth sounds great, it also is aesthetically beautiful and your use of it is astounding.
What did you use to connect so many potentiometers? An arduino?
Thanks! I think it’s one Axoloti connected to a Doepfer MIDI interface, used to make DIY MIDI controllers.
Thanks, I used 1 Axoloti and 1 Doepfer USB64 for the pots. Switches and leds where used with axo and the cc knobs (pots) to the Doepfer USB64. Axo and Doepfer are connected with midi together . Axo uses usb connection to Ableton for the different channels. Doepfer is powered with a seperate adapter.
Thanks. I designed my panel layout with Inkscape, than let it printed on 3mm thickness alluminium, drilled myself the wholes etc...
I used 1 AXO and 1 Doeper USB64. These are connected together with midi cable. AXO connections with only swithches and leds, Doepfer with alle the pots. Doepfer is powerd seperatly.
Do you need to start Axoloti first, and then start USB64 - or can you power both up simultaneously and get the correct result?
I want to build one, but I'm not a graphics person. Would it be possible to share a file to print the face plate? And share the complete patch code?
