All the explanation of the synth can be seen in the video.
Watch the video on a descent pair of head phones or good speakers
West Coast Synthesis - Demo
Recall knob position at startup in stand alone mode
This is just amazing. Congrats for the hard work!
Edit: just watched the full video, nice demo as well!
WOW
Amazing, congratulations.
Not only your synth sounds great, it also is aesthetically beautiful and your use of it is astounding.
What did you use to connect so many potentiometers? An arduino?
Thanks! I think it’s one Axoloti connected to a Doepfer MIDI interface, used to make DIY MIDI controllers.
Thanks, I used 1 Axoloti and 1 Doepfer USB64 for the pots. Switches and leds where used with axo and the cc knobs (pots) to the Doepfer USB64. Axo and Doepfer are connected with midi together . Axo uses usb connection to Ableton for the different channels. Doepfer is powered with a seperate adapter.
Thanks. I designed my panel layout with Inkscape, than let it printed on 3mm thickness alluminium, drilled myself the wholes etc...
I used 1 AXO and 1 Doeper USB64. These are connected together with midi cable. AXO connections with only swithches and leds, Doepfer with alle the pots. Doepfer is powerd seperatly.
Do you need to start Axoloti first, and then start USB64 - or can you power both up simultaneously and get the correct result?
