I use two Axoloti Boards, on being feed in as a send return insert for the other. Information is being passed between the 2 boards via midi.
Since setting up the audio send/return is quite annoying with stereo breakout cables I thought about using the 2 unused pins of the midi connector for the audio connection.
I see that these have solderpoints on the boards. Could I just use these? Theoretically this should be M1 and m3 right?
Next question is: If I solder from the audio in and out pins above the Gpios can I still use the Stereo Jack I O?
