Using ubuntu 14.04
kernel 3.13.0-61
When I connect the device to a USB3 port and start the program, I get these kernel errors:
kernel: [ 8028.550607] xhci_hcd 0000:00:14.0: WARN Event TRB for slot 4 ep 4 with no TDs queued?
This message is repeated about a thousand times per second, causing my HD to fill up with log files (/var/log/syslog & /var/log/messages) , which after a few hours crashed my laptop, and almost made it impossible to restart (reboot took about 20minutes).
Workaround: don't use an USB-3 port.
