Thanks. Not sure I understand the technical description but nevermind, I´ll google it.
Does the Axoloti need to be powered from the cellphone? Or do you mean that it is 'being forced' to need it due to the design philosophy of the Axoloti (IIRC; anything connected to the micro USB port disconnects the DC-jack)?
Whereever I´m searching for information there are keywords as USB OTG, USB host, USB Tethering, USB Debug Mode. And on top of that: all seems to be mixed up with no clear information wether if it´s the same (which I doubt) and/or what´s what. It just adds to the confusion.
Liine Lemur:
"Connectivity — Lemur Android supports OSC and MIDI over Wi-Fi, as well as over USB with 3rd party tethering utilities."
TouchDaw:
"Later versions add support for MIDI over tethered USB connections, ADB and WebSockets. A free driver, available from our website, is required for those. As of version 1.4. the app can also be used with class-compliant USB MIDI interfaces on devices that support USB host mode."
MidiCommander:
"IMPORTANT NOTE: the Android device MUST BE CAPABLE of acting as USB-HOST. So, please, do not rate the app with a low score if the connected midi device is not recognized: it might be that your android device does not work in USB-HOST mode."
Anyway, whereever I´ve searched regarding S4 Mini / S5 Mini there are no indications of them being able acting as USB-hosts. I´ve found the USB-debug mode on my S5 Mini, but I haven´t found any information of what that really means. I find it hard to believe that USB debug mode itself suddenly would make any Android device working as USB host.
My S4 Mini screen is broken, but a relative easy/cheap fix if I repair it myself. Given that it would be fully functional after a repair, I don´t really have a use for it since I´ve got my S5 Mini. But it would have been wonderful if it could become a sort of remote midicontroller to the Axoloti, instead of bying a new tablet/phone only for that very purpose (not really justifiable).
Although I do have an Arduino Mini and Uno, Raspberry Pi 2. As well as the Up-board incoming (I think in april 2016 or so). An hack are an solution, but I think it might be too difficult to start with being a noob as I am...
