i'll try it out but to be honest it isn't even the full Edirol PCR50 that I have..its some cannibalized version that is missing the necessary controller for me to switch around the internal settings (to turn off advanced mode that switches off the roland stuff and make the device class compliant). I can try it anyway and of course I can try my A-800PRO in advanced mode. I think it is best we remove that entry of mine from the nonworking list because my device is not even in one piece and not fully operational.
USB Midi Controllers
I briefly played around with an ALESIS V25 on the axoloti. basic keys + knobs were all working (found no issues so far)
M-Audio Axiom 49 (2nd generation) also works file, I can assign knobs, faders, pads and modwheel without any problems.
Is the stand-alone operation with USB MIDI controller a prove that the controller is supported or is it enough if it works while in 'Live' mode when also connected to the Patcher? I just assume both is the same. If the later is true then I can confirm that the C-Thru Music Axis-49 works with Axoloti.
Its enough that the controller is directly connected to the Axoloti board's host port... 'live' or standalone doesnt make any difference to the firmware.
the only thing to 'exclude' is if the controller is connected to a PC/Mac which is then redirecting it thru the Axoloti Core device (eg. using USB device mode), as this is more about the PC/Mac sending via USB device.
Akai MPD26 seems to be working fine via USB midi, just needs more power than axoloti can provide
just to say that it works fine with the Behringer UMX610 controller keyboard, keys and knobs
You can add extra power through the DC input connector with a wall-wart power supply. 7-20V, center pin positive.
You can monitor the actual 5V voltage in the main window. If it drops to below 4.5V when plugging in your USB device without external power supply, I advise to use an external power supply.
@johannes, if you power thru the usb micro port (i.e. with a USB charger) is the current still limited to 500mA? or can it pull more?
(with multiple boards, Im thinking of using a powered USB hub as a power distributor, with the added advantage a single cable and then be taken to a host mac/pc for patching editing :))
Power input through the micro-usb port is current limited to 1A average. Power output on the USB host port is current limited to 0.5A average. The red LED lights up when detecting overcurrent on the USB host port.
Hi, thanks for great project, and for sending a much smaller box, than i expected
I`ve just tried Behringer BCR-2000 connected to Axoloti, and it works. I set BCR to mode U-3, but all usb modes should work.
One question OT here : what was motivation for naming a project "Axoloti" ? Just curious...
Works perfect with Teenage Engineering OP1 also with keyboard and internal sequencer.
