Hey!
I'm having troubles with executing my patch from SD, the Upload to SD as startup option produces a console message returning a success, but the patch doesn't load. This behavior persists after power-cycling the unit with an Android charger instead of the regular USB.
Upload to flash seems to do the trick every time, but it seems I have to do a firmware reset before uploading a new patch.
If I leave it plugged into the computer via USB, the patch seems to load but my MIDI controller isn't connected.
What is the priority for a patch if there is one both on SD and flash?
Cheers!
