Since recently I can only briefly connect to axoloti. It then disconnects, making it (virtually) impossible to upload a new patch to axoloti or develop a new patch.
I get
> connected
> Authentic Axoloti Core
> Firmware version: 1.0.0.1, crc=0xF8C49AE8, entrypoint=0x20011000
> Disconnect request
and when I do try to connect again
connected
java.lang.Exception: cpuserial has wrong length
at axoloti.HWSignature.Verify(HWSignature.java:96)
at axoloti.USBBulkConnection.connect(USBBulkConnection.java:321)
at axoloti.MainFrame.jCheckBoxConnectActionPerformed(MainFrame.java:848)
at axoloti.MainFrame.access$400(MainFrame.java:92)
at axoloti.MainFrame$7.actionPerformed(MainFrame.java:473)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6535)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
Disconnect request
It feels like something is seriously wrong. I thought It was my patch, but I succeeded in flashing the sine osc tutorial, and the behaviour is unchanged. Although right now I'm totally unable to flash anything.
any ideas/remedies?
Thanks
