Decided to try and work out why I cannot contribute to Github, have gone through the video several times, have tried both my github ID and email, password is correct etc, but everytime I get the as shown below error when I "Init" the preferences and try to sync libraries, is there something I am missing.. Thanx...
org.eclipse.jgit.api.errors.TransportException: https://github.com/axoloti/axoloti-contrib.git: git-receive-pack not permitted
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:164)
at axoloti.utils.AxoGitLibrary.push(AxoGitLibrary.java:533)
at axoloti.utils.AxoGitLibrary.sync(AxoGitLibrary.java:87)
at axoloti.menus.FileMenu.jMenuSyncActionPerformed(FileMenu.java:264)
at axoloti.menus.FileMenu.access$400(FileMenu.java:51)
at axoloti.menus.FileMenu$5.actionPerformed(FileMenu.java:134)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
Caused by: org.eclipse.jgit.errors.TransportException: https://github.com/axoloti/axoloti-contrib.git: git-receive-pack not permitted
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:505)
at org.eclipse.jgit.transport.TransportHttp.openPush(TransportHttp.java:387)
at org.eclipse.jgit.transport.PushProcess.execute(PushProcess.java:155)
at org.eclipse.jgit.transport.Transport.push(Transport.java:1250)
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:157)
... 43 more
