Following your questions, I updated the "rockafella" patch.
I have created another version that may be of interest to you.
sampler.rockafella.agoraphobe.axp (18.2 KB)
If not for the constant clicking noise, this one is brilliant in terms of functionality. Tried messing with the attack and release parameters on the rbrt objects but they didnt seem to change the clicks. The ability to reverse the sample seems to be gone as well. But as far as the length knob goes, that seems to work (minus the clicks)!
edit: don't hear any difference when moving the chunk size parameter either, so maybe that's what's causing the clicking? idk
Sorry for the late response. I don't have much time to look at your problem.
For the ability to reverse the sample, the modification is not too difficult, you should find the solution on the forum (If this becomes impossible for you I could take 5 minutes to help you
). For the "click" problem, I don't know. I suspect the difference in speed between recording and playback.
I updated the main patch (axoloti-contrib/patches/gao/sampler.rockafella.axp) to correct some problems. I also updated your patch. Maybe this will fix the click problem.
sampler.rockafella.agoraphobe.axp (18.1 KB)
Hey. Thanks a lot. It's still clicking quite a lot each time the table starts again, so unfortunately it's a bit too annoying for me to listen to, but I really appreciate your effort and I'm sure others will learn as much as I've done from looking at all of the solutions you've come up with! Thanks again!
