Hi there!
I made a very simple mod of fx/rngs/reverb. I'm not a coder and I just tried, unexpectedly it worked: I wanted a mono version without lowpass filter so (if I recall correctly) I copied all the files in a new folder and edited them removing everything regarding the right channel an the filter...
As said it worked but since then I got a duplicate UUID warning, that I politely ignored...and used it successfully for a while in my live performing patch.
Since yesterday I'm the happy owner of 2 more axos and so I'm changing my setup a little bit, and I run into another problem: if I run 2 instances of my modded object they kinda feedback (maybe they write to the same buffer?), and If I run 1 rngs/reverb and 1 mod the patch don't compile.
Start compiling patch
Compiling patch... with /opt/Axoloti/app/firmware
BDIR = /home/p/axoloti/build
FIRMWARE = .
RM
APP
! /home/p/axoloti/build/xpatch.h.gch
. /home/p/axoloti/objects/rings_fx.h
. /home/p/axoloti/axoloti-factory/objects/dist/bltable.h
. /home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h
In file included from /home/p/axoloti/build/xpatch.cpp:3:0:
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:6:6: error: multiple definition of 'enum rings_fx::Format'
enum Format {
In file included from /home/p/axoloti/build/xpatch.cpp:1:0:
/home/p/axoloti/objects/rings_fx.h:4:6: error: previous definition here
enum Format {
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:12:6: error: multiple definition of 'enum rings_fx::LFOIndex'
enum LFOIndex {
/home/p/axoloti/objects/rings_fx.h:10:6: error: previous definition here
enum LFOIndex {
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:18:8: error: redefinition of 'struct rings_fx::DataType'
struct DataType { };
/home/p/axoloti/objects/rings_fx.h:16:8: error: previous definition of 'struct rings_fx::DataType'
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:21:8: error: redefinition of 'struct rings_fx::DataType<(rings_fx::Format)0u>'
struct DataType {
/home/p/axoloti/objects/rings_fx.h:19:8: error: previous definition of 'struct rings_fx::DataType<(rings_fx::Format)0u>'
struct DataType {
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:35:8: error: redefinition of 'struct rings_fx::DataType<(rings_fx::Format)1u>'
struct DataType {
/home/p/axoloti/objects/rings_fx.h:33:8: error: previous definition of 'struct rings_fx::DataType<(rings_fx::Format)1u>'
struct DataType {
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:49:8: error: redefinition of 'struct rings_fx::DataType<(rings_fx::Format)2u>'
struct DataType {
/home/p/axoloti/objects/rings_fx.h:47:8: error: previous definition of 'struct rings_fx::DataType<(rings_fx::Format)2u>'
struct DataType {
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:64:7: error: redefinition of default argument for 'rings_fx::Format format'
class FxEngine {
/home/p/axoloti/objects/rings_fx.h:61:21: note: original definition appeared here
Format format = FORMAT_12_BIT>
/home/p/axoloti/axoloti-factory/objects/fx/rngs/rings_fx.h:340:7: error: redefinition of 'class rings_fx::Reverb'
class Reverb {
/home/p/axoloti/objects/rings_fx.h:259:7: error: previous definition of 'class rings_fx::Reverb'
class Reverb {
/home/p/axoloti/build/xpatch.cpp: In member function 'void rootc::instancereverb__1::dsp(const int32_t*, const int32_t*, int32_t (&)[16], int32_t (&)[16], int, int, int, int, int)':
/home/p/axoloti/build/xpatch.cpp:5092:8: error: 'class rings_fx::Reverb' has no member named 'set_lp'
reverb.set_lp(q27_to_float(param_lowpass));
/home/p/axoloti/build/xpatch.cpp:5099:34: error: no matching function for call to 'rings_fx::Reverb::Process(float [16], float [16], int)'
reverb.Process(left,right,BUFSIZE);
/home/p/axoloti/build/xpatch.cpp:5099:34: note: candidate is:
/home/p/axoloti/objects/rings_fx.h:271:8: note: void rings_fx::Reverb::Process(float*, size_t)
void Process(float* left, size_t size) {
/home/p/axoloti/objects/rings_fx.h:271:8: note: candidate expects 2 arguments, 3 provided
Multiple include guards may be useful for:
Makefile.patch:57: recipe for target '/home/p/axoloti/build/xpatch.bin' failed
make: *** [/home/p/axoloti/build/xpatch.bin] Error 1
Compiling patch failed ( /home/p/axoloti/patches/VAL/board2.axp )
Sorry for the long log but I wasn't able to paste it "windowed"...
Are maybe those problems consequences of wrong uuids? Any help appreciated
