Hi there! im afraid im gonna make another newbie question again.
Is there an object that you can enter gate signals and pull trigger signal? and the opposite? its there and object that you can enter trigger signals and pull gate signal?(in this last case it would be nice if you can decide how long the gate is. with a knob if it possible.)
Maybe I should explain a little why im asking that. Im working on a "live" sampler machine based on this video from Mathew Tyas
(They are great tutorials BTW)
The main difference its that im using Twister Midi Fighter to sequence the 4 tracks. I find 2 main problem (for my knowledge level.....witch it very basic).
FIRST: the midi channel of the Twister Midi Fighters knobs (cc messages) and buttons (midi note messages) its 1
and the sequencer of the Twister Midi Fighter send midi notes and CC messages using channel 8.Which its good cause I already assigned al the knobs and midi notes of channel 1 to control all the audio effects a added on the patch and I still have channel 8 for the sampler controlling ... I read something about subpatches so you can have different midi channels in the same patch... but didn't jump to that rabbit hole yet. first I need to resolve the second problem.
SECOND: the sequencer from the Twister Midi Fighter send a gate on each step so if i active two consecutive step I only get the first one to trigger my sampler. Thats why im thinking in a gate-to-trigger or trigger-to-gate object or way to patch it my self.
Any suggestions? THANKS
PD: it will be also very nice to have the. drj/midi/note_tx but receiving version. It will be much more easier to control patches receiving midi from different midi channels.... just saying
This object its not working for my needs ... But I just remembered I had this same problem trying to build a CV sequencer for triggering circuit bended toys. I gonna have to check if I find the right schematic but AND logic gate and using the clock signal an the gate signal together was the solution.... I will have a go with it and post here my result... maybe anyone will have the same problem in the future.
