Hi, i was thinking about building some kind of touch sensitive controller, where you can use your hands to control certain parameters as well as a percussive device.
Now i found this project: https://www.expressivee.com which is even going further than i expected.
sample video: https://www.youtube.com/watch?v=wgvDo-oDGF8
it seems quite advanced and with 400 € reaching quite deep into your pockets.
I don´t want to recreate the same instrument, but a diy solution.
Could you share your thoughts, what could be used do measure pressure and movement, like in a X,Y, and Z axis, mixing them together to control certain parameters?
any input is welcome.
thank you
