toneburst/pattern/nmpgen2.axo
(includes help file)
Status
Active
My second Axoloti Object!
A version of nmpgen.axo, 32-steps max now, but with realtime-controllable Length parameter and added Offset control, to rotate the pattern.
I plan to add extra features in future updates. So far on the list:
- Trigger pattern output, based on last bit of pattern output value
Note:
- As with nmpgen.axo, I can't guarantee that future updates won't change the pattern that is produced with a given parameter configuration. I'll lock this down soon though, once I've decided on the best random number generator setup
- The numbers on the Length and Offset controls aren't accurate. The actual numbers are half the rounded values displayed, so they only change ever 4 steps of the knobs
