I'm trying to build an axoloti version of the Moog Minatuar and I have found the beat/osx/multiWave object which I think might be able to work as the oscillators. I want to toggle the waveform on the object using a physical button, but the input is expecting an integer (1-4) and I can't seem to find an object to take a gate (yellow) output from the button and use it to rotate through the values 1-4 for each button press.
This seems like something that someone has done already, but maybe I'm not looking in the right place.
Cheers.
