Start compiling patch
java.io.IOException: Cannot run program "C:\Program" (in directory "C:\Program Files\Axoloti\app\firmware"): CreateProcess error=193, %1 is not a valid Win32 application
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
	at java.lang.Runtime.exec(Runtime.java:620)
	at java.lang.Runtime.exec(Runtime.java:450)
	at qcmds.QCmdShellTask.Do(QCmdShellTask.java:114)
	at qcmds.QCmdProcessor.run(QCmdProcessor.java:190)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=193, %1 is not a valid Win32 application
	at java.lang.ProcessImpl.create(Native Method)
	at java.lang.ProcessImpl.(ProcessImpl.java:386)
	at java.lang.ProcessImpl.start(ProcessImpl.java:137)
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
	... 5 more
Compiling patch failed ( C:\Users\user\Documents\axoloti\axoloti-factory\patches\demos\youtube\tybett.axp )
Start uploading patch
bin path: C:\Users\user\Documents\axoloti\build\xpatch.bin
FileNotFoundException,java.io.FileNotFoundException: C:\Users\user\Documents\axoloti\build\xpatch.bin (The system cannot find the file specified)
	at java.io.FileInputStream.open0(Native Method)
	at java.io.FileInputStream.open(FileInputStream.java:195)
	at java.io.FileInputStream.(FileInputStream.java:138)
	at qcmds.QCmdUploadPatch.Do(QCmdUploadPatch.java:65)
	at axoloti.USBBulkConnection$Transmitter.run(USBBulkConnection.java:885)
Disconnect request
Done uploading patch
USB device found
connected
