Technical question: power source
In order to increase the number of pots on my controller I have added an mcp23s17 and two mcp3008 chips. I was wondering if they need dedicated power from the 5v source behind the midi connectors or if they are powered via the connector I have added to bridge my sawn in half axo. Or do I need to source power elsewhere? I don't get a response when I test their functionality at the moment and I want to make sure this is patch-related rather than a hardware issue
Its OK to tap into both the 5V power on your bridge connection, but use the GND on it as well, just to keep all your connections in order. I powered a completely separate midi controller this way as a substitute for batteries. Worked fine, switched on every time the Axo was powered.:grinning:
