Tables and patch/patcher macro objects
Is there something special I need to do to have an object inside a patch/patcher reference a table object at the root of the parent patch?
I'm not having much success doing that, at the moment.
a|x
if the table located in the main patch is called "drums" ... You should put this in the object reference in the subpatch:
../drums
../ makes the reference to the parent patch... If you are 2 subpatches deep:
../../drums
And so on.....
Thanks, I'll try that. :slight_smile:
a|x
