I'm trying to sync multiple Axoloti boards with DIN MIDI and I ran into some problems.
Some things I've tested that work:
* Axoloti 1 connected with DIN MIDI cable to Axoloti 2. When I start the clock on the first board, the second board syncs perfectly.
* Electribe as master clock, connected to Kenton MIDI Thru 5. Axoloti boards and Ableton Live sync perfectly.
The problem however is this: Axoloti 1 as master clock, connected to Kenton MIDI Thru 5. Ableton Live syncs, as well as the Electribe. The second Axoloti board doesn't sync. Any ideas on how to debug this?
My ideal setup for performances would be one Axoloti board as clock generator, and three other Axoloti boards running in sync, all connected to the Kenton MIDI Thru 5. I want to perform without a computer, and I don't want to drag the Electribe with me.
