Sync Libraries failure
I'm using Win 7 and Axoloti version 1.0.12-0-g80370d2
I haven't had problems in the past seeing new objects from the community, but none of the newest posts from the last month are available to me. When I try to sync libraries I get this:
Sync Successful : factory (1.0.12,anon)
Sync (pull) FAILED : community (1.0.12,anon)
org.eclipse.jgit.api.errors.CheckoutConflictException: Checkout conflict with files:
objects/tiar/dist/DP inv2.axh
objects/tiar/dist/DP type IIA and PM.axh
objects/tiar/dist/DPHardClip.axo
objects/tiar/dist/rectify.axh
objects/tiar/dist/rectify.axo
objects/tiar/filter/ZDF SVF 1.axo
objects/tiar/lfo/triphase_vlfo.axo
objects/tiar/osc/Osc_Bnk_I.axh
objects/tiar/string/mux2.axo
at org.eclipse.jgit.api.MergeCommand.call(MergeCommand.java:419)
at org.eclipse.jgit.api.PullCommand.call(PullCommand.java:331)
at axoloti.utils.AxoGitLibrary.pull(AxoGitLibrary.java:331)
at axoloti.utils.AxoGitLibrary.sync(AxoGitLibrary.java:70)
at axoloti.menus.FileMenu.jMenuSyncActionPerformed(FileMenu.java:264)
at axoloti.menus.FileMenu.access$400(FileMenu.java:51)
at axoloti.menus.FileMenu$5.actionPerformed(FileMenu.java:134)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
Caused by: org.eclipse.jgit.errors.CheckoutConflictException: Checkout conflict with files:
at org.eclipse.jgit.dircache.DirCacheCheckout.doCheckout(DirCacheCheckout.java:420)
at org.eclipse.jgit.dircache.DirCacheCheckout.checkout(DirCacheCheckout.java:402)
at org.eclipse.jgit.api.MergeCommand.call(MergeCommand.java:293)
... 44 more
search path : C:\Users\System User\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\System User\Documents\axoloti\objects
search path : C:\Users\System User\Documents\axoloti\axoloti-contrib\objects
finished loading objects
theres some problem with files listed being changed 'inconsistently' , hard to say exactly what
anyway solution is simple, reset the libraries
file->preferences->reset all
Now I have zero objects... (??!?!)
Axoloti version : 1.0.12-0-g80370d2 build time : 02/02/2017 20:39:14 CET
Link to firmware CRC E95BAC96
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
Saving preferences...
preferences path : C:\Users\System User\Documents\axoloti\axoloti.prefs
java.lang.NullPointerException
at axoloti.object.AxoObjectInstanceAbstract.resolveType(AxoObjectInstanceAbstract.java:179)
at axoloti.Patch.PostContructor(Patch.java:364)
at axoloti.PatchGUI.PostContructor(PatchGUI.java:771)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1006)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1025)
at axoloti.FileUtils.Open(FileUtils.java:166)
at axoloti.menus.FileMenu.jMenuOpenActionPerformed(FileMenu.java:255)
at axoloti.menus.FileMenu.access$200(FileMenu.java:51)
at axoloti.menus.FileMenu$3.actionPerformed(FileMenu.java:107)
Sync (pull) FAILED : factory (1.0.12,anon)
org.eclipse.jgit.api.errors.NoHeadException: Pull on repository without HEAD currently not supported
at org.eclipse.jgit.api.PullCommand.call(PullCommand.java:197)
you said yes, to delete all directories?
Ive done the same here, and its working fine...
usually this is caused by network issues, or not being able to write files to the directories?!
but cant think why you are getting it.
you could try closing down axoloti,
deleting the library which are in:
axoloti-contrib, axoloti-factory
and then restarting...
no particular reason it should work, but its very unusual for reset all not work, as it basically just deletes the directories and then redownloads them from GitHub
Yes. I puckered up because it seemed like a bad option.
I removed the two folders (contrib and factory) from the Axoloti directory, restarted Axoloti but it didn't download the folders.
Tried your reset procedure again, and now only some of the objects have returned. Should just manually download the folders from github and place them in the directory?
Some but not all of my objects won't reload. Please help me to understand and correct.
When I look at the actual directories, I can see that there are new objects included, yet these are not options when I try to add them in the patcher...
I know this is a terribly un-sexy and boring problem but I am in dire need of assistance or at least some level of understanding. The end-user, non-coder, non-DIY person begs you. Please.
When I tried to sync libraries, no new modules arrived. I then deleted them as suggested. Now many of them are "removed." I don't understand what is happening or how to repair this.
Status: factory (1.0.12,anon) : OK ( 1.0.12,dirty )
Changes for: factory (1.0.12,anon)
removed: objects/disp/ibar 64.axo
removed: objects/midi/ctrl/index.html
removed: objects/osc/brds/fluted.axo
removed: objects/sel/sel 4l 16 8t s.axo
removed: objects/lfo/saw down lin.axo
removed: objects/audio/index.html
removed: objects/midi/in/keyb note.axo
removed: patches/tutorials/test_signal_generator.axs
removed: objects/script/oneliner_s.axo
removed: objects/conv/bipolar2unipolar.axo
removed: objects/logic/index.html
removed: patches/tutorials/20_karplus_strong.axp
removed: objects/disp/dial p.axo
removed: objects/pulse/lfsrburst 8.axo
removed: objects/midi/in/cc hr i.axo
removed: patches/demos/sensors/ribbon.axp
removed: objects/harmony/note scale.axo
removed: objects/table/table.axh
removed: objects/env/d.axo
removed: objects/harmony/note scale.axh
removed: objects/mix/mix 3 sq.axo
removed: objects/patch/send b.axo
removed: objects/midi/intern/bend.axo
removed: objects/spat/pan.axh
removed: patches/hug/midi_io/extra_midi_io.axp
removed: objects/jv/lkm1638/lkm1638-buttons-leds.axo
removed: objects/jaffa/ctrl2/t16m.axo
removed: objects/rbrt/data/wave creator 32.axo
removed: objects/tiar/dist/fractalI_multiSin.axh
removed: objects/rbrt/control/demux_sh.axo
removed: objects/sss/edrum/CY4.axo
removed: patches/mtyas/WaveTables/TURING33_2048.raw
removed: objects/sss/filter/3bandCross.axo
removed: objects/phi/disp/boolx4.axo
removed: objects/rbrt/disp/disp float b.axo
removed: objects/rbrt/old/steptoggle.axo
removed: objects/sss/osc/2DdualOsc.axo
removed: objects/tiar/math/triple STARc.axo
removed: objects/sss/env/ADloopR.axo
removed: objects/sss/mix/mixsix.axo
removed: patches/pmj/pmj_math.axp
removed: objects/sptnk/sequencer/euclid.axo
removed: objects/phi/harmony/scalerf.axs
removed: objects/jv/lkm1638/lkm1638-leds.axo
removed: objects/rbrt/seq/step write 4.axo
removed: objects/sptnk/sequencer/fibonacci astarb.axo
removed: objects/rbrt/old/loop_drive.axo
removed: objects/sptnk/effect/noise gate.axs
removed: patches/sptnk/test wavetable creator.axp
removed: patches/cpwitz/effects/mod-filter-array.axp
removed: objects/phi/logic/counter maxshift.axo
removed: objects/phi/prob/%gate.axo
removed: objects/sss/ctrl/buttonFunctions.axo
removed: objects/phi/switch/sw 1-2f.axo
removed: objects/phi/osc/slowsine.axo
removed: patches/tiar/synths/HarpsyRing.axp
removed: objects/rbrt/data/tinit 16.axo
removed: objects/sptnk/math/combinator.axo
removed: objects/sss/math/divScale.axo
removed: objects/tiar/kfunc/b2u.axh
removed: objects/klab/logic/last_rising_4.axo
removed: objects/rbrt/testing/tables_3.axp
removed: objects/sptnk/split/split 4 symm.axo
removed: patches/tiar/exp/MetallicHorizon.axp
removed: objects/sss/gain/expLPG.axo
removed: objects/tiar/osc/6coseg.axh
removed: objects/euxo/1-2/in/gate_in1.axo
removed: objects/rbrt/testing/ldrive nointerp.axo
removed: objects/tiar/osc/6coseg.axo
removed: objects/sss/math/scaleInOut.axo
removed: objects/sss/lfo/planetLFO.axo
removed: patches/tiar/GM/041-Violin-tiar.axp
removed: objects/sss/fx/pcf.axo
removed: objects/lokki/settings/formantsettings.axo
removed: patches/mtyas/messymix/blackbox/with touchboard/grain.axp
removed: objects/jaffa/sel/sel i 32 64D.axo
removed: objects/sss/disp/4xchartB.axo
removed: patches/mtyas/WaveTables/metal.raw
removed: objects/tiar/string/mux4.axo
removed: objects/sss/dyn/compSTSC.axo
removed: objects/sptnk/sequencer/chorder.axo
removed: objects/phi/math/divmul i.axo
removed: objects/tiar/kfunc/b2u.axo
removed: patches/tiar/bass/DigiCode.axp
removed: objects/sptnk/math/knee s.axo
removed: objects/tiar/osc/CosCosAM2.axh
removed: objects/sptnk/sequencer/clock out dual.axo
removed: objects/tiar/osc/wf12/wf_12Steps.axo
removed: objects/sss/env/hahdEnv.axo
removed: objects/jt/tuning/adjustable.axo
removed: objects/lokki/math/triggerindex 8.axo
removed: objects/sss/edrum/DR5.axo
removed: objects/sss/osc/supersaw.axo
removed: objects/sss/ctrl/bipInt.axo
removed: objects/sss/delay/shimmerDelay.axo
removed: objects/rbrt/midi/in/table store FULL.axo
removed: objects/phi/math/div 3f.axo
removed: objects/sss/filter/fir16mod.axo
removed: objects/jt/tonewheels/tri dpw.axo
removed: objects/phi/logic/counter3 max.axo
removed: objects/sss/delay/splicer.axo
removed: objects/sss/fx/pitchshifter.axo
removed: patches/mtyas/messymix/blackbox/with touchboard/niceperc.axp
removed: objects/sss/env/syncEnv.axo
removed: objects/drj/lfo/lfo_pwm.axo
removed: objects/sss/patt/ReCntMem2.axo
removed: objects/sptnk/effect/waveshaper 16p scope.axo
removed: objects/sss/env/Dcrv.axo
removed: patches/janifr/synth/drawbar_organ.axp
removed: objects/jls/logic/logistic_gate.axo
removed: objects/sss/harmony/scaleGenerator.axo
removed: patches/mtyas/messymix/Sebti/seq1.axp
removed: objects/sss/harmony/tune.axo
removed: objects/jls/logic/logistic_gate.axh
removed: objects/sss/osc/STO2.axo
removed: objects/ptttr/seq/seqrec64.axo
removed: patches/phi/shuphil1.axp
removed: objects/sss/sss/softClip.axo
removed: objects/phi/lfo/slowphasor.axo
removed: patches/lokki/octaver.axp
removed: objects/tiar/dev/AxoEnString.axh
removed: patches/mtyas/messymix/blackbox/Striso2/grain.axp
removed: objects/lokki/bassformantvoice.axs
removed: objects/sss/osc/subSine.axo
removed: objects/jaffa/env/d2 lin.axo
removed: objects/sptnk/sequencer/euclid length out.axo
It goes on like this...
i said delete the entire directory... both factory and community
do not just delete the directory contents, which is what you have done, hence the 'removed' messages.
i also have no idea why the 'reset all' does not work for you,
we have done this with lots of people, and its always worked - it was the 'full back solution' , i tested recently it works for me on both windows and mac.
i can only think its something to do with either your network connection, or perhaps something on your system (anti virus) interfering.
when you do the reset all, are you getting any errors, if so post the entire console, i need to know exactly what is going on.
so its not about being boring or not... its just from what you've told me so far, I'm not really sure why your system is different from everyone else.
I had done that.
No that is not correct.
It exceeded the character limit for posting!
Despite the same settings as always, this was somehow preventing the download. I disabled it and the sync worked immediately.
Well, you left me hanging after it broke, despite my request for further assistance.
I'm an unpaid volunteer here... i come here when i have time, and i post when i have something to say... and as I said, i was a bit stumped... this process has worked for everyone else in the past.
(as you can see, my suggestion about anti virus, is pretty much a guess, ive no idea if you have an anti virus installed, and if so which one... nor which ones are failing - as we have never seen this for the libraries before - as i said, a guess only)
then put it in a text file, and upload it to somewhere like dropbox and post a link... as i said, full logs are important, what a user thinks is 'not important'/relevant may not always be the case.
cool, glads its working for you now.
#11
Hello - sorry to add to this thread, but it's the same issue and I'm hoping for assistance to get myself working again.
I've come back to Axoloti after building the Music Thing Modular controller. Community and Contrib folders had content, but were not syncing and had disappeared from the patch-builder since I last used Axoloti.
No changes to my iMac since I last used the board - that I can recall - and folders in the same place.
I deleted Contrib, Community and Factory folders, restarted and got this:
USB device found
connected
file error: FR_NO_FILE, filename:"/START.BIN"
Apologies for basic errors...
regards,
1_n
#12
Okay, it took 15 minutes to reset libraries - and the folders are replaced in the main 'Axoloti' folder, and folder contents are now showing after restart.
Still getting file error message:
connected
search path : /Users/n/Documents/axoloti/axoloti-factory/objects
search path : /Users/n/Documents/axoloti/objects
search path : /Users/n/Documents/axoloti/axoloti-contrib/objects
Does this mean I have to do a make-over and start the process again?
Regards,
1
#13
that means you don't have a startup patch on your sdcard...you can ignore that file error warning.
#14
This makes sense - thank you!
