Hey
In Axoloti editor you have 8 presets in a row on top of the editor. These are very useful and makes it easy to set up some nice presets. From 9 and up it gets a little bit harder cause you cannot assing them in the same simple way as first 8. You have to right click each parameter and assign them, etc.
Would it be possible(and make sense from a developers point of view) to expand those 8 "easy assignable" preset button to 16 for example?
To me that would be very useful.
What do you think? Maybe the space is saved for something else?
In 1.0.11 some of the space is filled up with the cable colors, but there is still room for some more presets, imo
Or maybe the easy assignable presets menu could be reconfigured to be a dropdown menu, where you select which preset you want to edit. The dropdown menu would not take a lot of screen space and could cover a much larger number of presets than 8.
(By easy assignable presets i mean the "edit" presets menu)
